Clip in pedals?
Alex808
Member
Im getting a new bike and im wondering if its worth spending money on clip in pedals and shoes, and what difference do they make?
Yep, they're worth it; first upgrade but you have to count in shoes, cleats and pedals into the equation so you'd be lucky to get them all in for under £100 but could do it for a touch more...then, you have shoes for their lifetime and pedals that you can keep to use on another bike when the time comes.
Go for it, you won't regret it.
slowmotion
Quite dreadful
lost somewhere
When you buy the pedals, check that they come with cleats. Some Ebay sellers leave them out, and they cost a lot if you buy them alone.
BTW, most people fall off their bikes soon after getting started. It concentrates the learning process quite splendidly.
Good luck....it's worth it:thumbsup:
Deleted member 20519
My pedals and shoes costed me £50 all in, they don't give me any significant power increase but they give me sore knees,
QBPNick
Member
I had the issue with my knees at first as well. But it went away after about a week. And you don't notice the advantage of riding clipless unless you're on longer commutes/riding hills/loaded heavy.
I say it's worth it.
Davehateshills
Bury, Lancashire
I had a £5 voucher from CRC so I picked up the pedals for £14.99 (SPD's) I then got the shoes for £29.99 from Lidl (good shoes) so for under £50 I am clipped in and WOW, what a difference! I can assure you that it has been the most significant move forward in terms of cycling performance since I started cycling. Do it, you will not regret it!
Well I've been riding clipless for several months and I've always had sore legs, I just can't seem to position the cleats in an optimal position. I do, however, like them on rainy days when your feet would slip off of flat pedals and I like them when I'm up out of the saddle climbing hills, I can feel the benefit there.
you won't get any increase in power from using clipless pedals - power comes from your legs, not from your pedal choice. Sore knees is probably down to an incorrect set-up.
Saluki
World class procrastinator
If you are getting a new bike, why not ask if the dealer will throw in a pair of SPDs with the bike. They quite often will, then you only have shoe expense to worry about.
