Clincher tyre pressure- how low can you go?
palinurus
Velo, boulot, dodo
Watford
Ok, I guess it would depend on rider weight, tyre, course conditions etc. but what sort of pressure can you get away with when using clinchers?
RedBike
Beside the road
You'll find the main problem with running low pressures, espeshially if your heavy or riding aggresively, is pinch flats.
Hit a large rock with 'only' 40/50 psi and narrow cx tyres and there's a very good chance you will pinch flat. However, the good news is cx course don't tend to have rock gardens, just soft grass/ mud. In which case you can probably get away with running the tyres as low as 30psi. Any lower than this and the tyres wont roll right or handle right!
You need to experiment and find what works for you.
For a fast course on hard ground pump the tyres up a bit. For the mud let them down a bit.
palinurus
palinurus
Velo, boulot, dodo
Watford
Cheers, just what I needed- a rough guide of where I want to be with my pressures and where I could reasonably go.
