Clicking from front mech
deadonkey
Hi.
Got an issue with my Cannondale hybrid that every time I transfer weight from one foot to the other I'm getting a clicking noise, it's almost like a double click per transfer of that makes any sense.
Doesn't do it when there is no load on the bike.
If I just freewheel the cranks it doesn't do it, doesn't do it if I lift the back wheel off the ground. Only when I'm actually cycling.
The bike is around 3 years old, hasn't had much use until the last few months.
Anything I should look out for?
I've felt for play in the main crank bearing and there is none.
Job for my LBS?
young Ed
bit of crud or s**t in the BB bearing?
Cheers Ed
Spain
[QUOTE 3326938, member: 45"]Gear cable end catching your foot?[/QUOTE]
This ^^^, i've also had my cadence sensor and magnet hitting each other. Or speed magnet and sensor hitting each other.
slowmotion
Quite dreadful
lost somewhere
Loose crank bolt made the same noise on my bike once.
