astrocan
- Abingdon, Oxon
Not long ago I replaced the cartridge bottom bracket with a set of external bearings. Not too many miles on there is a pedaling related clicking noise coming from down below. It sounds like the grease has escaped from the bearings and now at the top of each rotation the balls are dropping down and clicking onto the next one. How can I get some grease in there as the life span is going to be about zilch if it carries on like this. I took the chain off and span the crank and there was no noise, I took the crank out and there is some wear on the non-drive where the tube goes through the bearing. I can see no obvious way of repacking the bearing so any experience gratefully recieved.
