Brian Stacks
- Chelmsford
What is the difference between fixed and floating cleats?
The 'float' degree, is pretty much an acceptance angle for the bind. The greater the 'float' the less accurate you have to be with your foot, to re clip / clip in. So higher degree float cleats are better for the unaccustomed. The down side is that there is a bit more lateral movement of the foot when clipped in, so it's easy to waste energy / not have the leg aligned / at the cost of efficiency.What is the difference between fixed and floating cleats?
No energy is wasted as a result of cleat float. Not sure where you got that from.
Float or no float is just a matter of personal choice.
It's called experience, and many many thousands of miles of riding.
If there was power loss WRT float, then off road racers with their SPD's and the relative tons of float would be losing power hand over fist no?
Just no. Off roading is totally different to road riding.If there was power loss WRT float, then off road racers with their SPD's and the relative tons of float would be losing power hand over fist no?
In what way?
You do need a fixed SPD / SL etc. cleat setting up properly, or you'll suffer on a long road ride.
You need float on SPD / off road cleats, or you'd spend most of your time getting unclipped unintentionally. The nature of off roading (sharp / steep climbs, and bursts of acceleration) mean that any losses due to movement of the feet really don't matter. You don't want your legs mis aligning on a steady state road ride, it is energy wasteful, over the sorts of distances covered in road riding. You do need a fixed SPD / SL etc. cleat setting up properly, or you'll suffer on a long road ride.
