Cleaning and Re-Greasing Bearings
Octet
Well,
I thought it was about time I tried to do more than simply lubricating the chain and doing your average "aesthetic" clean of my bicycle (Raleigh Airlite 400 2011, with Shimano 105 Derrailleurs and Chainset), so I have decided to strip, clean and re-pack my wheel bearings.
Using information I have found on the internet, I think I have sussed it however I would appreciate some input or corrections.
For the front wheel, I will need a a 15 and 17mm spanner. To remove it, all I need to do is simply turn the two in opposite directions and then the entire inner piece shall slide out with bearings visible and ready to be cleaned and re-greased?
For the back wheel, I need a chain whip and a lockring removal tool as well as the 15 and 17mm spanners? I turn them in opposite directions and that removes the cassette, I then need to remove the jam and cone nuts using the spanners in the same way as the front?
When I come to re-assemble, how will I know if it is too tight? Is it simply a case of ensuring it spins freely whilst not being too lose?
Finally, how do I know if I have a sealed bearing on my bottom bracket, if not does this need stripping and re-greasing?
For all these various bearings, what sort of grease should I use? I have a tub of Lithium Grease however I don't know if this is too thin?
Thank you in advance!
Shut Up Legs
Down Under Member
To remove the nuts on the rear hub, you'll need cone spanners (just very thin spanners, common sizes are 15 and 17mm). I normally use general-purpose bike grease. I wouldn't use the thin lithium grease, though (I have a spray can of this), because it might be too thin (but I'm no expert, and happy to be corrected on this).
As for the bottom bracket, the HT-II (Hollowtech II) cartridge ones typically look like mine below. Here's where I'd just removed both cranks, and was about to undo the 2 outer cartridges. You can also see the Park Tool BBT-3 bottom bracket tool.
Octet
Octet
Ah right, thanks for the information!
I'm currently filling my Wiggle shopping basket with the various tools I think I need:
Lockring Tool
Cone Spanners (both 15 and 17mm)
Chain Whip
From what I can gather, my BB is sealed so it can't be serviced (unless I'm mistaken) and it doesn't need replacing as of yet.
The Lithium Grease I have certainly can't be sprayed, it's almost the consistency of warm Vaseline, in truth I think it is designed for wheel bearings but I've read so many mixed views, including some saying it will harden.
lpretro1
Unless you have a very old bike the bb will be a sealed unit - whether it be a square taper one or external cups - neither can be serviced. Just fit new. Recommedn you use a teflon based grease rather than lithium - that goes to powder after a while and not as water-resistant.
gbb
Peterborough
Regarding the hubs, are they quick release axles or solid ?
quick release axles are a little trickier to adjust...if you adjust them 'just right', then fit the wheel and tighten the QR...it nips the axle a tiny bit and the hubs will then be a bit tight. The knack is to adjust them JUST a bit loose, then when you tighten the QR, theyre just right.
First time I did mine, it took a few adjusts to get them just right.
Octet
Octet
They're Quick Release, thanks for the suggestion about keeping the hubs a bit loose. :thumbsup:
simon.r
Person
Nottingham
Good advice, I was just about to post something very similar.
