Cleaning A Bicycle Chain
Wester
My chain is pretty dirty and i need to clean it without removing it from the chain rings / sprockets what is the best way to do it and the best solution to use
Also what effect does a dirty chain have on the well being of your bike
This forum has a great search function! ^_^
HovR
Plymouth
A dirty chain can cause accelerated wear of drivechain components, poor shifting and sometimes excess drivechain noise.
The best way to clean a chain on a bike is just to get a lot of rags, and wipe it till clean. Covering the rags in something like GT85 helps in serious cases. After you have cleaned the chain, apply lubricant.
The alternative is to buy a specific chain cleaning tool, however these use horrible solvents and wash the lubricant out of the inside of your chain - so not ideal.
kayaker
Regular
midlands
This post reminded me, something i wondered about the mickle method, is that wiping will clean the side plates but what about in between the plates and the pins? Thanks in advance for any enlightment.
Chris
Linford
A small quantity of paraffin, a 1" paintbrush, and a bit of elbow grease :thumbsup:
Linford
Paraffin is a solvent. NOT recommended.
Eh - he is asking for an effective cleaner, and parafin is just that - Clean properly, and then re lube.
How do you think they lube the chains in the factory after assembly ?
U
User482
Paraffin is unnecessary and counter productive. Mickle will tell you why.
Linford
If you use a chain wax, this will hold the grit. I favour a really thorough clean, and fresh lube. Not sure what Mickle does
