Claud Butler identification help
Chrispy
Member
Hello
Just joined, in the hope of getting some info on the CB I have just acquired.
The bike has been added to over the years, but I hope the pictures will be helpful!
Chrispy
Gunk
Oxford
Looks like a Majestic, late 70’s early 80’s I rebuilt one a couple of years ago. Have you got the frame number?
https://www.cyclechat.net/threads/1982-claud-butler-531-majestic-project-10.269399/
Dag Hammar
Essex
I have a CB Majestic and my model does NOT have wrap-round stays, if that is any help.
There’s a small hole in the frame just above the Claud Butler badge, does that imply that there used to be a ‘proper’ metal badge there originally ?
C
Chrispy
Member
Ooops, sorry - thanks Gunk! (I’m a bit new at all this)
I see your location is Oxford - mine too. Happy to show you the bike some time for an expert opinion, if you’re interested!
C
Chrispy
Member
The frame number should be stamped on the underside of the bottom bracket.
If not, then look on the seat stays or the chain stays.
Had a search there for the frame number yesterday - unsuccessfully. Did find “Made in France” stamped on a rubber / plastic pad across which the cables run, though…
