SteCenturion
I am your Father
- The Dark Side of the Moon.
Hi y'all.
I have been lurking around in other sections of CC Towers for a while now & have recently been getting all rose spectacled over some Steel road race frames.
I have lots of questions for you connoisseurs of quills & lugs & I am hoping to learn from you experienced folk out there so that come the time, I don’t make a right horlicks of it.
Broken down (as plain as poss)
1. Columbus SLX - in the hierarchy of tubes, where does this sit against other Columbus or Reynolds tube sets & is it fairly lightweight for steel ??
2. If I found the right frame (and one just got away) what spacing between rear dropouts would allow modern 10 speed groupo to be fitted. ?
3.What spacing for 9 speed as above question ?
4. Is it possible to fit a modern stem & bars instead of those long necked jobbies (Quills ?? are they called) ?
5. I would want to run modern sized 700c rims, what enables this & what restricts/prevents this ?
6. Can I fit a carbon post to a steel seat tube (as with Alu) same goes with forks ?
I will leave the questions there as I may have already asked too much.
The Plan.
To find a good quality, excellent condition frame & build up with at least modern group set & wheels, historical accuracy unimportant.
The Dream.
A Custom build from any of these, Feather, Swallow or Brian Rourke, in a high end tube set such as 953, 853 or Columbus.
Cheers very muchly in anticipation of your kindly responses.
The Plan.
The Dream.
