Classic Parts?
jonsidneyb
I am going to guess this is considered a classic.
I have a Trek 520 made in 1986. I destroyed a crank lever, chainring says Shimano on it.
Is there anyway to tell what model this is and how I might go about finding the part?
compo
Harlow
Unless you are wanting to keep the bike as original as possible you don't have to replace the cranks with original equipment. From the 1980's I would assume it is a square taper fitting onto the bottom bracket and the world is your oyster for replacements. Just match the crank length and number of teeth on the chainrings and any LBS, or even Hafords, will be able to fix you up.
J
jonsidneyb
Thanks, I was thinking about staying original but I could change. I will have to do everything mail order. There are no LBS's in a very long distance from me.
