3tyretrackterry
- East Midlands UK
i have seen the retrofit problem solver cablestops for frames and seatstays. does anyone know if they can be bought for rear stays and also the clamp on down tube shifters what size is the bolt that holds the levers on. i would like to use some old mid 90's cable stops and need to know if they will fit the bosses fitted to a clamp on system
Many Thanks
Many Thanks
