Two questions in one here. The reason for which is that I have some light niggly rattles in certain gears and it's annoying. The rattles aren't a major deal, but the bike is running so smoothly now, that it would be a shame not to track them down.
Anyway, I had the bike on the stand, before I went away for a week, and it appears that the the noises ease up an awful lot when a push the rear dérailleur forward slightly while pedalling. Noises come back when I release. Indexing is all perfect, but B Tension screw does absolutely nothing. Doesn't even get to the point where it would pull the dérailleur away from the hanger.
Some reading online suggests that the tension may need adjusting, but I am not 100% on how to do this?
When in the gears that are noisy, the rear cage appears to be out of alignment slightly, but the cage has an angled shape to it, so not 100%. I know that the hanger is perfectly aligned, so no need to go down that road.
What is the best way to check and adjust dérailleur cage alignment?
Incidentally, the noisy gears are those which form the cogs which are individual, with individual spacers between them on the cassette. Doesn't happen on those lower gears which are joined together. Is this something I should expect?
