Check your cranks?
DCLane
If it happens - and it has once to me - you can feel the crank loosening about 30 seconds before it comes off.
Cranks falling off, what's this ? TBH, it depends on the crank system how easily they might come off'. I can see hollowtech coming off much easier than GXP or Square taper (I've got all three) if things aren't tight.
Milkfloat
An Peanut
Midlands
A friend had a groin to top tube coming together after his hollowtech crank came off 25 miles after a new bottom bracket from his LBS. After we finished laughing we had to push him home 15 miles because the splines were totally knackered.
raleighnut
With any crank I've fitted I have a little test ride (4-5 miles) then check em for tightness, a lot of the time they've 'settled in' and do need a tweak. BTW this has been with every type of crank from cottered to hollowtech, the nicest/best system I've owned is my TT bike with Campagnolo Centaur (10spd) which has a 'Hirth Coupling' in the centre.
It’s part of any sensible ‘M check’. It’s one of the reasons we do it.
Levo-Lon
I'm of the opinion, if you ride in a group you'll get injured eventually.
Crank coming off while sat? Bit unlucky
MontyVeda
I'm a bit baffled by this. Didn't the cyclist know they were getting loose?
My cranks used to regularly come loose until I started carrying a long 8mm Allen key... they spent a lot of miles feeling loose rather than just coming off all of a sudden.
London
Maybe he's one of those cyclists who entrusts his bike to bike shops for services and doesn't do much himself.
I don't actually test ride as such my square taper installs but like you carry a 8mm key around for a while and check and tighten a few times on the first rides. It seems to need tightening at least once at the beginning, then all is fine.
(come to think of maybe he's also the sort who would be horrified at the idea of carrying round a full size 8mm key)
edit - just re-read the initial post more closely - yep, seems he relies on someone else to keep things tight.
Trust he'll recover - might be an idea to peruse the Park Book with a cup of tea while he's laid up.
presta
I've never had a crank come off, but I had one break:
506703
My mother's partner gave me his bike to repair a puncture once, it had about 30 degrees of free play on the crank. He'd ridden it loose until the axle had chewed a lump out of the cotter pin, so that when he tightened it the nut just ran up against the end of the thread. From the vacant look I got when I replaced it, the improvement was lost on him.
It probably depends on whether or not the bolt falls out before the crank works loose on the taper. I went into the LBS to buy a crank tool once, the guy just gave me a blank look and said "What do you want that for, we just take the bolt out and jump on the pedals until the crank comes off".
MontyVeda
In my experience, the crank works loose on the spline/taper as soon as it's got somewhere to go. i.e. the bolt is slightly loose. I can't see how the bolt can work itself out all the way without the rider noticing a bit of wobble on the crank.
I've advised folk on here many a time to do similar to what your LBS does if they don't have a crank tool... loosen the bolt, ride round the block and the crank will come loose in no time.
