RichardB
Slightly retro
- West Wales
I've just finished a build of a lightweight frame and fitted the rear mech. I've cleaned, overhauled and repaired these in the past, but never fitted a new one. In particular, I have never had to mess with the B tension screw. Photo below is of the mech on the largest sprocket (it's a 14-28 block, single 44T at the front). Does it look right to you? I have the mounting bracket correctly fitted behind the lug on the frame hanger, and from the angle of the pulleys I think I have the chain length about right. But I expected the guide pulley to be a bit closer to the sprocket than this. I have read anything between 5 and 10 mm between the teeth of the pulley and the teeth of the sprocket. The gap here is about 14 mm. I have tried screwing the B tension screw in and out but it seems to make no difference at all to the angle of the pulleys. You can see in the photo that it is fully out (which in my understanding means the pulley should be closest to the sprocket) but screwing it all the way in doesn't move the mech a millimetre either way. H and L limit screws are set correctly and the mech changes up and down as it should on the bike stand, but I know that sometimes what it does on a stand isn't necessarily what it does on the road under pedalling pressure. Weather and roads have been too wet for a road test yet.
Am I missing something obvious (in which case, educate me please) or does it look fine and I can stop overthinking it? Thanks all.
