Hi all, I have a frame with a BB90 already fitted but I got a second hand Fulcrum wheelset with Campagnolo hubs. Is it a simple case of just taking out the Shimano BB and putting in a Campagnolo one? Say from Athena or Centaur groupset?
Thanks very much for these pointers. I see that FSA cranksets are often compatible with Campag and Shimano/SRAM, so would you be aware of a FSA crankset that I can run with Campag chain, derailleurs and cassette?
Just to follow up on this I believe I need to use a Hollowtech II crankset with the press fit bottom bracket (incidentally I have bb91 not 90), so if I were to get the 105 or Ultegra Hollowtech II crankset would this be compatible with an otherwise Centaur 10 speed drivetrain?
I have an Ultegra triple chainset working happily with Campag shifters and mechs so I don't see any reason why your suggested setup woud not work. The front mech is probably the least sophisticated part of the drivetrain and so most quality shifters will work with most decent chainsets, regardless of make.
