Salty seadog
Space Cadet...(3rd Class...)
Morning all,
What are the collectives thinking on changing into a lower gear whilst riding uphill? To my mind and experience it must be done under minimal or no loading on the drive train. With this in mind it can only really be done at the bottom of the hill as you lose momentum and whilst you have enough speed to ease off for the change down. Without taking the load off you are putting an enormous strain on the chain trying to lift it onto a bigger sprocket which could cause damage as I believe may have happened to mine during a badly executed change.
See the link pulling apart.
Once you are crawling up it is impossible to change gear without running the risk of damage.
Not sure what I want from this but there it is, take it and run with it.
Ssd...
Ssd...
