Angelfishsolo
A Velocipedian
- Cwmbach, South Wales
As the title says is it possible to move from a 44 to 48 tooth outer chain-ring without changing the front mech?
Take the 'limit' as a guide not an absolute. You could certainly stretch it some. I'd be looking at lifting the changer and seeing if you haveclearance for a 48,while the chain on the 22 ring does not faul the bottom of the mech. You need to clear the big ring, as you change from middle to big, by an extra 8mm or so. If you can set it like that a 48 will fit, the change might be less slick but 32 to 48 is only 16 teeth and I run a 24 40 55 on my QNT with decent changing.
Beware one point AFS...i did this on my sons bike. The 48 fouled the chainstays. I got round it by putting a different BB on. Technically i suppose i gave it a poorer chainline, but it worked.
