Changing brake cables
Milkfloat
An Peanut
Midlands
If you are changing outers then absolutely - if just inners my answer would be, it depends.
smutchin
Cat 6 Racer
The Red Enclave
Unless they're Stainless.
Or the ones with an anti-friction coating.
cosmicbike
Perhaps This One.....
Egham
Assuming Shimano or SRAM brifters then both gear and brake inners can be replaced without touching the bar tape. You need to peel back the rubber covers on the hoods and then you can simply pull out the old, push in the new.
