is there an easy way or a trick to changing brake blocks. I always seem to have a battle sliding the old ones out and the new ones in. Using Swiss stops so "changing the cartridge" isn't the answer, I have to change the blocks in the cartridge?
Depends. Sometimes they can be a pig. Remove brake pad and prise it out of the carrier with a screwdriver. I usually push them with a blunt object to slide them out. Pushing down on the garage floor usually shifts them.
