oldgreyandslow
- Farnborough
I have eventually replaced the cartridge bearings on my Fulcrum Racing 5's. I used SKF 6001 2RS as advised on a previous post. Pulled the bearings in using a bolt, socket and suitably sized washers and nut etc. The tube that fits between the bearings inside the hub seemed a bit loose, but not excessively so. Fitted it all back together, very little pressure on the spindle nuts reassembled and its as stiff as a very stiff thing, loosened everything off, skewers barely pressing on it etc and its still very stiff.
I can only assume the bearings aren't lined up correctly, or am I missing something?
Any advice or suggestions welcome.
Ta
Ta
