Andy in Germany
- Rottenburg am Neckar
I've got a couple of bikes in for repair with worn chainwheel (?) sets, and trying to replace them. Problem is that they're not all the same, and this area of bike maintenance is beyond my current knowledge.
Firstly, here's an example of the type of chainwheel in need of replacement (The item to be replaced is still on the bike):
And here's the most common type in stock:
One has the socket (?) for the square taper axle recessed, and one is flush with the granny gear.
So far so good, I understand that I need a different length axle (as opposed to a different length barrel) for these two, but then the axles come in a bewildering array of lengths: 107mm, 110mm, 113mm and then in leaps and bounds to 127mm.
How do I find out which axle is the correct length for a chainwheel, especially when I don't always have an old BB to hand? Sheldon Brown seems silent on the matter, but that may also be because I don't know the English terms for the items so any help there is also welcome.
