Grouchfungus
- Herts
Disaster of a ride tonight.
I'm a newbie so please bear with me here....not sure of the correct tech names for all the bike bitz.
Got halfway round the ride. Chainset/pedal assembly fell off. The securing bolt had sheared off. Limped home for 4 miles having to tap the chainset/pedal assembly back onto the spindle every couple of revolutions.
Will it be possible to get the broken thread out??
And replace with a new hex bolt? The chainset was recently repaired by the LBS as the largest cog was bent.
The bike's a Specialized Hardrock BTW ....
And replace with a new hex bolt? The chainset was recently repaired by the LBS as the largest cog was bent.The bike's a Specialized Hardrock BTW ....
Just bad luck then.
