Chainring confustion???????????????
dave5069
hounslow
Hi Lads and Lasses,
can someone out there explain what is the differance between a compact chainrings and normal chainrings? and what one is best to find and why?
I know i'm a bit thick but if you don'task then you never know lol.
Paulus
Barnet,
A "normal" chainring/crankset will have any where between 45 to 53 teeth on the large ring, 38/43 on the smaller/inner ring and if you have a granny ring20/30. A compact crankset will normally have a 50 on the large and a 34 on the inner. No granny ring. A compact will help you if you have a double chainset, ie Two rings and live in a hilly area. It gives you a lower gear range so easier going up hills but not quite as fast on the flat.
