You might want to give sjs a call, they seem to know a bit about cross compatibility per
this.
While often true one should not rely on same bcd rings being always compatible. I can tell you that some of the xtr and xt rings e.g. are not interchangeable despite having the same bcd's because of the raised or recessed profile at the holes, or that Campag's 110mm bcd compact rings actually has one hole offset...
