stoatsngroats
- South East
I have a Pioneer triple (it's on my tandem,and no, I've never heard of them either!),and having just changed chain and cassette.
The middle ring is unuseable, as even a slight bit of effort on the pedals makes the chain slip. The bigger, and smaller rings are much better, although I haven't riden standing on the pedals (I have a back problem, causing pain, so just fettling today!)
The teeth on the middle are very pointy, like sharks fins, on the big ring the teeth are slightly finned, and on the small ring, the teeth are square topped.
I think the cranks are square taper, and they are fitted to the rings with 4 bolts.
So, my question, can I change just the 2 worn rings, if so, is i just a matter of removing the crank, and unbolting the 2, or can I just unbole the chain rings, leaving the crank on?
Or do I have to replace all three rings, and the cranks?
Thanks for your guidance!
SnG
SnG
