Richard A Thackeray
'Two Parter'
I bought my Ribble CGR, back in March
On Sunday, I replaced the chain (as a precaution/to save cassette/chain-ring wear)
I recall that the chains, on the 'blue' Ribble didn't last as long, & the cassette also needed replacement*
It had (I think) 4 chains & 2 cassettes, in 3 years I used it
It was my year round, as commuter/trainer/'do it all' bike (even out with local Triathlon Club on it)
The CGR's seen a lot more use, than the 'blue' did, as due to constant little aches/pains/'niggles', I've not run to work as much (I'll be lucky to run 1,000 miles this year)
It all seemed cleaner, less worn, no grittiness in the links
I'll conjecture, that as there's not the grime/brake-dust mixture falling onto the chain/cassette, from a standard caliper brake; be it dripping onto it, whilst riding, or if propped up at an angle which allowed it to drip onto chain
Therefore less wear!
Am I right??
Plus;
Still getting an odd noise from the front disc
The best description is, that it's like a freewheel ratchet
At first, I thought it was just the actual freehub resonating through the frame, as I braked - tightening up the forks/headset interface
But it still does it, if I'm pedalling
Shimano RS505 STI / Hydraulic Disc Brake Set w/RS785 Calipers
Clarks Dirt-Dissipation rotors
I did initially think it was a compatibility problem, but if it was I'd have the same problem with the rear, but that's fine
* No chain on it now, & it needs another new cassette (as it's just stood in a corner, since the CGR arrived)
Am I right??
Plus;
