Chris S
- Birmingham
Does anybody know how this type of chain splitter works? What's the screw at the end for?
That tool looks like it has a large pin. Does it have an optional finer pin?
The screw pushes the pin onto the rivet, to break the chain, you hold the tool by the handle with one hand, turn the screw with your other hand.What's the screw at the end for?
I've got a chain splitter like this, except for the knurled screw at the opposite end to the handle. I'm guessing it's some sort of end stop, i.e. to stop you pushing the pin out too far. Normally I recognise when the pin has been pushed out just the right amount to let you split the chain without losing the pin but, if I'm right on this, it wouldn't half be great if by adjusting the knurled screw you could just merrily turn the handle without risk of pushing the pin right out.
Where did you get it from, I want one!!!
Sorry, I didn't explain myself very well there lolIsn't the lever on the other end supposed to do that ?
When you place the chain in the slots of the chain tool, the chain will be slightly loose and that hollow screw is just tightened up against the chain by hand to hold the chain tight/ square as the pin is pushed into it by the levered screw.
