cardiffgareth
Member
- South Wales
Hello!
Post 3 and another tech question!
If I pedal normally, i.e. not hard all is good with the chain and cogs but if I put it into a high gear and really push hard on the pedals as if to build up speed every now and then it clunks and its like the chain slips off the front cog, like its missing a tooth on the front cog? Only briefly and then all is good again for a while and it'll do it again?
I thought maybe the chain was worn as to me (and I'm no expert!) but the front cogs look good to me so I went to Halfords to buy a new chain but he said it could be the front bearing thing that screws into the frame and to check the pedals for side play. Done that and they're rock solid with no movement. He also said it could be the front derailleur hitting the chain and causing it but looking at it the front derailleur isn't touching the chain?
Any ideas ?
Thanks in advance!
Any ideas ?
Thanks in advance!
