Melonfish
Evil Genius in training.
 - Warrington, UK
I've done 1200 miles on my dawes Mojave 2011 since the end of may.
recently i've been getting chain slip on the cassette when in my normal cycling gear.
its a 7 speed cassette with 3 cogs. i usually cycle in the middle cog and use either the 6th (second smallest) or 5th gear (third smallest) gears, where i am is quite flat or if i'm motoring i'll use the 7th gear quite happily.
now i've been noticing that the chain slips when in the 6th gear middle cog. it doesn't do it if im in the big cog or the little, its knocked my confidence in the bike because i'll be on a busy roundabout and the chain is slipping, or i'll stand up to get over a smallish hill and the chain will slip.
i've adjusted the barrel adjuster and that appeared to work for about 5 mins, now i'm stuck with some chain slip and a finicky downchange.
what should i do with this? i really need advice, i've never indexed a derailler before
 does it need this or is it something more serious?
also, no visible signs of chipped/cracked cogs on the cassette, i checked thoroughly.
thanks
pete
 does it need this or is it something more serious?also, no visible signs of chipped/cracked cogs on the cassette, i checked thoroughly.
thanks
pete
