I inherited a (fairly crappy) "Probike Escape" mountain bike and rode it on trails until I broke the freewheel. Since I had to replace the (6 speed) freewheel/cassette, I also replaced the chain and since then, it skips under load, but only on second and third largest rear cogs - every other gear is fine. I can't get it to skip when I flip the bike upside down and pedal with my hands.
I've done a fair amount of forum bashing to try to fix this and here is what I've tried:
Here are some other possible suggestions - good to get some views on these:
Any other bright ideas?
Thanks,
- The usual cause of skipping with a new cassette and chain is the front chainring. However, it still skips on all three of the front cogs and because it doesn't skip on any cogs except 2 and 3 on the back, that doesn't seem to fit.
- I wasn't sure if I had put on a chain that was too short, so I put in a few extra links. No difference.
- Another cause of skipping I spotted is the b-screw adjustment on the rear derailleur. This bike's rear derailleur did not have a b-screw, so I replaced it and fiddled with the b-screw a few times but no luck - it still skips on 2 and 3.
- I did wonder if the new cassette/chain/chainring are not compatible in some way, although I did try to buy carefully. I bought a 6/7/8 speed Shimano chain and a 6 speed freewheel
- There is quite a lot of rocking on the rear hub - when the rear wheel goes around you can see the cassette rocking back and forth. I guess I was reluctant to address this because I was trying to avoid rebuilding the hub.
Thanks,
