[QUOTE 3725201, member: 9609"]I am under no illusions that my little test is not being carried out under scientifically controlled parameters, and I am under no illusions that those who dislike the results will say the test was flawed.
[/QUOTE]
Not knocking you, I have found as you have that chains easily last 2,500 to 3,500 miles and thats in all conditions as I can ride quite a bit, I had one chain cassette combo last about 8,000 miles I was changing from 8 to 9sp, just took longer to save up than I thought it would, mind you most of it was 9sp compatible FD and RD 3300 cogs on the rear mainly from a 9sp cassette with 8sp spacers, I have until recently run either KMC 73 or 93 chains be it 8 9 or 10 sp. I am not meticulous but the chain is always clean after a wet ride same method, though I probably put a tad more oil on than a drop on each roller but not much.
