hackbike 6
- The Mile End Road.
For the seventh time recently my chain has broken...
This time near to home and without me falling off again...
The bike has been "serviced" about 200 miles ago by a well known bike shop and the "problem" went for alas 200 miles.
Managed to get to work this morning with no problems but then it suddenly kicked off again although I know what my big mistake was splitting the chain and rejoining it as it seems like nowadays you cannot split chains as it makes them weaker with a 90% chance of breaking again.
After the last break I fitted a 9 speed chain on a 10 speed cog and although this worked I found it very unstable so I changed it,it had a powerlink thingy.
After my local shop fixed it,the chain was fine but then suddenly when cycling through Tower Gateway in the rush-hour the chain was found to be toot tight on the biggest cogs so they jammed.Managed to free them up and got home ok.So that's why I changed the chain for the only complete albeit wrong size chain I had.
I also had a sort of inquiry as to why this has happened and I now realise that the cog on the back (which is 10 speed) the lowest gear cogs ratio is wrong which means I can't take too many links(it's not the original wheel or cog) off and I probably cant use the lowest front ring as the chain would be to slack.
Im fed up with this 10 speed cog crap anyway,can I get something like a 7 speed cog on the back?
I remember in the old days I used to have only 10 gears in all and used to manage so why I need twenty gears really beats me.
Bike is Dawes Audax 2006.
Any help and advice would be appreciated.Cheers
