PrettyboyTim
- Brighton
In December I replaced the chain that had come with my bike. Using the ruler method, I determined that the chain had lengthened by about 1/16th of an inch (over a span of a foot), so I replaced the chain with a new SRAM one with a powerlink. Now, since then I've done probably around 500 miles but yesterday I noticed that everything did not look okay with the chain.
I noticed it first on the front cogs; the chain looks like the links are too long for the teeth seperation on them. When the chain first meets the cog, the teeth are resting against the front of the link as you would expect, but as you go around the cog, the teeth begin to move from the front of the link to the back of the link, as you would expect if the chain had lengthened. Looking at the cogs themselves, there's no visible bad wear (the teeth are still symmetrical and don't look worn down), so I'm wondering what's going on. I've been wiping down and re-oiling my chain fairly regularly, and I've given it a couple of soaks and scrubs in white spirit since it was put on, so it's not been neglected.
Unfortunately I couldn't find my tape measure to measure any stretch yesterday, but surely the chain can't have lengthened already? It's new! When I last took the powerlinks off, the pins in them didn't show any signs of wear, so I'm beginning to wonder if the pitch in the SRAM chain was a little bit different to the one my bike was supplied with...
Any ideas? I guess it might be worth getting one of those chain measuring tools...
