theoriginaldus
Hi guys,
I recently changed my chain and rear derailleur, this caused the chain to jump due to wear on the cassette, so I also changed that out but the chain is still jumping when applying too much pressure. Seated peddling is fine, but standing to take off from a stand for instance causes the chain to jump. Here's a bit more detail but I'm really at loss as to why this is still happening tbh, any thoughts appreciated.....
New chain, new rear derailleur, new cassette. Chainset looks to my eye fine and doesn't have enough wear to need changing out. I haven't replaced the rear hub but have overhauled it and replaced the bearings (racers look fine, the spindle isn't bent etc). The old cassette was off road but the new one I have fitted is a road cassette, however the rear derailleur has a long cage. Now I went into my local bike shop and they suggested that maybe I needed a short cage but tbh I'm not entirely convinced, I've already taken a couple of links out of the new chain and thoroughly checked for stiff links so I don't think its a tension thing Also the chainset is still an off road triple, so surely I need to have the long cage to take up the slack for that? (not that I use the inner ring at all and only rarely the middle).
One thing, the frame did get slightly bent meaning the derallieur was not straight and pointed in towards the wheel, so I straightened the little lip you screw the derallieur into and reinstalled it. With the derallieur exactly vertical, the chain was catching on the frame when on the smallest cassette ring so I ended up having the bend the lip out very slightly more, so the derallieur is pointing a little outwards away from the wheel, this is only very slight (a couple of degrees max), but might have some significance?
Oh yes and its not a shifting issue, the derallieur is lined up and reliably shifting between cassette cogs (I changed the cable here) and isn't between cogs or anything like that.
I'm by no means an expert on all this so there might well be something I've missed, I just wanted to get some more thoughts before I spend any more of my hard earned cash
Any ideas?
Cheers
Jon
Any ideas?Cheers
Jon
