Deleted member 35268
Would a very loose hub be enough to allow the chain to jump jump jump in the middle range?
WHAT DO YOU MEAN BY JUMP JUMP JUMP? (sorry for shouting, but I did ask earlier)Would a very loose hub be enough to allow the chain to jump jump jump in the middle range?
I think it can allow autoshifting by the middle sprockets being able to wobble back and forth enough to change which one aligns with the derailleur (which they can't when using one nearer the wheel) while the chain isn't being wrapped back as far by the derailleur (unlike in the higher gears).
A new bike because your chain is too short? Really? While I applaud your bike buying-fu (N+1 rules,obvs), you could fix what you have for a few quid.I think I have over shortened the chain, this means the gear cable tension is fighting with the chain tension, so it goes up and down the bigger cogs, I took it out at lunch and on a steep hill I came to a grinding stop. I also have a known issue with the hub so there is play. Basically I have shagged all my bikes and I need a new one.
The first one was a stiff link - a bit annoying considering it is a new chain.
You can, but it is easier with the bike the right way up, especially if the shifters are on the bars.I think a workstand would really help me sort my bike out, I currently have to flip the bike over and work on it that way. You can't really set gears up without a workstand.
