Hi all
Just fitted a new Shimano HG 7 speed freewheel to my Raleigh Record Sprint (Ultra 6 before) - all is good - except for some jumping on the small 13T cog - the extra width means the chainline leaves little space between the 15T and the chain as it comes off at the 12 o'clock position. Initially though the shift ramps or pickup teeth might be fouling. On closer inspection I realise the old Raleigh chain is taller and the chain is resting on the spacer (so not full engaging in the teeth). See the greasy marks on the spacer below (top right) and if you look at the chain you can see how tall the inner links are.
Measured the chain height and it's 9.5mm - check my daughters old £60 halfords special MTB and that's more like 8.5.
This looks to be the problem - anyone disagree with the diagnosis. I was thinking of a new chain anyway so was going to put an IG51 on - anyone know what the height is on that? (Can't find via on google - only the width).
Cheers
Steve
Cheers
Steve
