Hugh Manatee
I didn't know which forum to post this in for the best. Mechanics or Beginners? Most old hands would know this so I settled on sticking it here.
The problem with fitting the chain is that the spring in the rear mech makes life very awkward. You need a third hand!
Use an old spoke. Snip or hacksaw the bend off is it hasn't already snapped off. It is an old spoke after all. Now bend each end up just past the vertical.
There you go. Now hook an end into the chain, pull the other end in a bit against the spring and hook that one in as well.
You can now join the chain without the ends constantly trying to spring apart.
