Chain Coming Off
Hip Priest
Recently, I've had a bit of trouble with my chain coming off. It has normally been when I've been down-shifting whilst slowing for junctions or when I've been wheeling the bike out of the garage backwards.
The other day the chain came off when I was accelerating out of the saddle, with disasterous consequences (see other thread).
Anyway. Tonight I removed my cassette and gave it a proper degrease and clean. As far as I can tell, it is not worn to any great degree. I then replaced the chain.
I rode round the street a bit thinking 'Wahey, job done', when - you guessed it - the chain came off! What could be causing it? I'm guessing the fact it happens when I wheel the bike backwards means it could be a problem with the rear derailleur and / or jockey wheels.
I'm hoping it's something simple to fix...famous last words.
02GF74
not much detail given but do you have more than one chainring? if so, is the front mech adjust correclty?
is the chain the correct length?
Hip Priest
Hip Priest
I have a single chainring and an 8 speed cassette. How would I check if the chain was the correct length?
02GF74
let's back pedal as it were - I assumed it was coming off the chainring - correct?
to answer your question, chain is put on largest chainring and largest rear sprocket and add 2 links. it could be the derailleur is not keeping the chain under tension, either chain too long or spring is weak.
any stiff links in the chian? are teeth on chainring worn?
Hip Priest
Hip Priest
Correct
I'll check that out the morning, thanks.
The chain is new so shoud be fine. The teeth on the chainring haven't lost their shape either. I've done 1500 miles on the bike in total.
sidevalve
As above I'd check for any stiff chain links. A friend of mine had a similar problem with a newish chain, a stiff link that sometimes kinked, took ages to find what was going on.
Hip Priest
Hip Priest
Thanks for the advice guys. I'll check all suggestions tonight. Another question (sorry): Is there an easy way to tell from sight if a cassette or chainring is worn? The teeth still have there shape, but I'm concerned that running the same chain for 1500 miles may have ruined m drivetrain.
Hip Priest
Hip Priest
Right. I've tried everything, and it still keeps happening. It's going into the shop before I had a nervous breakdown!
Hip Priest
Hip Priest
As I've said, the hanger looks fine to me. It's going into the LBS tomorrow so I'll let you know the diagnosis!
Hip Priest
Hip Priest
Right, I've just picked the bike up from the LBS. And the cause of the problem was...a bent hanger! Not just a bent hanger but a 'badly bent hanger'. So I've learned that I'm blind and I should listen to Mickle!
