Chain came off cassetee
aravind123
Regular
Hi, so as I was trying to put my rear wheel back on I found that the chain had come off the cassette completely and I’m having a lot of difficulty trying to put it back on any help is much appreciated thnx. Ps iv added some pictures to try and show my problem.
I like Skol
A Minging Manc...
Nothing wrong there. You just need to put the chain back around the crank/chainrings by pulling it over the outside of the pedal/chainring and dropping it onto the inner/smaller chainring. Then you can refit the rear wheel as normal.
Cycleops
Accra, Ghana
You need to put the chain over the crank and chainring, perhaps resting it on the BB shell which will give enough slack to slip the other end of the chain over the cassette when you insert the wheel.
. When you've done that push the derailleur forward which allow you to slip the chain back on the chainring.
Welcome to the forum ^_^
