Hi All,
I've not been here for a long while... hopefully I'm welcome back!
How are you all?!
Now to business.
I have my eye on a 2011 Cervelo S3 frameset (as per the thread title) for a cheap(ish) little build project, but I've heard rumours that the tyre clearance is not generous and that even a 25mm Conti might struggle to fit on Cervelos of this era.
I don't mind using 23mm tyres, as I normally do anyway, but I've also been looking at some carbon wheels that as per the latest trend have a wider external rim width - namely 24mm.
Is the answer that if I buy an older frame I need older style narrower rims? Or will they fit in with a narrorwer tyre providing they're stiff enough not to flex significantly?
Anyone with any knowledge on the subject?
Cheers.
How are you all?!
Now to business.
Cheers.
