A few years ago Briko brought out a helmet called the "Twinner"
Basically a helmet with a second one on top
The concept that the outer helmet would be more aerodynamic without vents, and the gap between the two layers would cause sufficient airflow to cool through the vents on the inner layer. This relies on air being pulled through vents in the gap - the Venturi effect
Looking at the helmet on the TV it certainly looks high enough to be of this type of design, with vents beneath the outer clear layer but unless the back is visible then t is difficult to be certain
