spence said:
			...was I just unlucky today or is there a technique?
Went across my first cattle grid on the road bike today and it blew the rear tyre.  On the fat tyred bikes they're no problem, just ride across without worrying about them. So are they best avoided?
There's a a technique to everything.
But there's some variables too.
- Rider weight
- tyre pressure
- tyre quality
So, it would be helpful to know if you had the correct tyre pressure for tyre/conditions.
You say "blew the rear tyre" but I'm assuming you got a pinch flat Correct? If you actually blew the tyre, then that's a really extreme case.
Anyway, the trick is to "unweight' the bike as you cross by sort of jumping upward. This won't work very well, unless you have clipless pedals or toe clips and straps. The thing is, if you are a dead weight on the bike any good bump is likely to cause a pinch flat.
Combine proper tyre pressure w/ nimble bike handling and you'll reduce pinch flats.
As you know, fatter tyres reduce the problem. Another argument for more volume = faster and more comfy ride for the vast majority of riders.
