Ok I won`t bother with pictures as its already well documented elsewhere, the deed is done and its working, it looks brighter but TBH I really need to wait till total darkness. As for how easy it was, ermm
thats another matter, I wouldn`t say it was easy but its not hard.
1) I bought SSC P4 U bin stars, probably better buying just bare emitters.
2) If you buy the above be prepared to cut away all the excess PCB as they won`t fit other wise.
3) the screws holding it all togethor are crapola, typical japenese cheese head screws
4) Because of the shitty screws mine is just all glued in with the arctic adhesive, I doubt it will come loose as with the front cover on its very tight.
5) I had to make up new wires to join the stars togethor but they are cut too neat. you have to allow for movement round the inside curved shape of the base.
So in summary its working, from the outside it looks fine, didn`t need to reuse any of the screws or plastic plates from inside etc. Will post back tonight with updates on how freekin bright it is hopefully
