almostvegancyclist
- Wales
Hi all,
I got a new rear wheel with an aluminium freehub body (Mavic Allroad S), switching from Shimano with a steel freehub body. As I was tightening the cassette lockring, it felt a bit "mushy" like when you are stripping threads off. So I stopped the process, took the cassette off to see what was up and it looks like the smallest cog has dug into the tips of the freehub body splines, like in the photo (this isn't mine but it shows the same damage). Apparently this is "normal" for aluminium freehubs? Is that true? Should I not worry about this? The cassette is on and seems to be working fine.
