Casio Pro Trek F30 Dual-Layer Screen smart watch RRP£450 ex-demo. £189 posted
Kernow_T
Cornwall
Price includes RM special delivery. Any additional fees payable by buyer
Purchased this as ex display but it'd obviously been switched on and set up for demo so all factory reset and ready to set up (download the Google OS and Casio App and off you go).
This item has been unboxed, handled and demonstrated thus has a couple of tiny marks (inc one 2-3mm mark on screen) only visible under the absolute closest of inspections and difficult to photograph. These do not affect the any aspect of the functionality of the item whatsoever. All tags attached and accessories and paperwork included.
DESCRIPTION
The all new WSD-F30 is the newest member to the Pro Trek Smart family of outdoor smart watches. Full color map GPS navigation is available right on your wrist and can be used either on or off line so no connection is necessary once the maps are downloaded to the watch. This model has been updated with a dual-layer OLED/Monochrome display. The monochrome display will show the time and sensor information including altitude, barometric pressure and compass information while saving power by turning off the full color display. If you need to reference your map or other app info, tapping the screen or a twist of the wrist will activate the full color display. The WSD-F30 is 50m water resistant and compliant to Military Standard MIL-STD-810G testing so no mater what type of adventure you are on Pro Trek Smart is the perfect companion for all your outdoor needs.
Features:
  • GPS: Compatible (including GPS, GLONASS and Michibiki)
  • Color Maps: Compatible (supports offline use, can save up to five offline maps)
  • OS: Wear OS by Google
  • Display: 1.2-inch dual layer display, Color OLED (390×390 pixels) and monochrome LCD
  • Touchscreen: Capacitive touchscreen (anti-fouling coating)
  • Water Resistance: 5 bar (50 meters)
  • Environmental Durability: MIL-STD-810G (United States military standard issued by the U.S. Department of Defense),* low-temperature resistance (-10 °C)
  • Sensors: Pressure (air pressure, altitude) sensor, accelerometer, gyrometer, compass (magnetic) sensor
  • Microphone: Yes
  • Vibration: Yes
  • Battery: Lithium-ion battery
  • Wireless Connectivity: Bluetooth® V4.1 (Low Energy), Wi-Fi (IEEE 802.11 b/g/n)
  • Buttons: MAP button, Power button, TOOL button
  • Charging Method: Magnetic charging terminal
  • Recharging Time: Approx. 3 hours at room temperature
  • Battery Life (When GPS not in use): Normal use (color display): 1.5 day, roughly, Multi Timepiece Mode (timekeeping and sensors only)*3: 1 month, roughly (Varies according to use)
  • Size of Case: Approx. 60.5 × 53.8 × 14.9 mm (H × W × D)
  • Weight: Approx. 83 g (including wristband)
Use of the device requires a smartphone with the following specifications:
  • Android 4.4 or higher (excluding Go Edition) - Bluetooth capable smartphone which supports installation of Wear OS by Google from GooglePlay
  • One of the following models with iOS 9.3 or later: iPhone 5 or later - limited functionality when connected to iOS device, Wi-Fi environment required for iOS connection
  • Use of Android 6.0 or higher or iOS 10.0 or higher is recommended.
Included accessories:
  • AC adaptor
  • Charger cable
