Carry Freedom cargo trailer 'The Y' large, wide axle also available
Carry Freedom 'The Y' large trailer - ex-display, boxed and unused!
Superb mid-range lightweight collapsible cargo trailer. Not quite as beefy as Hinterher or Surly but much lighter, a lot cheaper and will carry 90KG. Simple to use, hitches to most bikes and stores flat again the wall. I've three more in use for events, mobile work and community projects and they just don't give me any issues.
Partially assembled for display at an event and then put pack in the box, so essentially brand new and complete. Can look at posting but it'll probably be spendy so would prefer collection. They currently sell for £460.00 not including assembly or postage.
£350.00 collected from Horsham, West Sussex. Happy to assemble and fit the hitch if that helps (and you bring your bike to collect).
SWAP: would consider swap for Brompton, 2007 model-year or newer with minimum 3-spd, preferably 5 or 6-spd. Cosmetic condition not critical, and neither is condition of tyres, cables, chain etc. So long as frame, fork, stem/steerer and hub are sound I'd be interested.
Wide axle beam for Carry Freedom 'The Y' trailer - 85cm (standard is 65cm) - ex-display
This is the optional 85cm axle beam for the Y trailers. Mounts underneath the built-in 65cm axle and generally used for wider or top-heavy loads to aid stability. Includes longer bolts. Mounted to the above trailer for display at an event and then put away again, never used. Currently sell for £72.00 plus shipping.
£55.00 collected from Horsham, West Sussex.
Pedropete
Pedropete
West Sussex, UK
Would consider swap for 2007 or newer Brompton, at least 3-spd, preferably 5 or 6-spd. Cosmetic condition and state of tyres, cables, chain, grips etc not important so long as frame, fork, steerer/stem and rear hub are solid.
