Based on another thread
are there motor cut-offs on the brake levers - and are these working
also - how do you know the motor is OK and the battery is working - just to eliminate people duplicating what you have already done
also - I suppose - are all the cables in one piece - I had a speed detector on mine that had a hole in the cable and messed things up!
Have you tried unplugging and re plugging the rear wheel connector?
Speed sensor??
control thingy on the handle bars - does that look OK?
if it is not realising that the bike is moving it can cause problems
not much else left!!!
Seems to me that everything is working
except the whole thing
Weird - which probably means we are missing something
Ideally you would have an identical bike and swap parts to and fro to make sure everything work OK on the other bike
and see if anything made the "broken" bike start working
I presume that is not possible??
Hello people. I have a carrera vulcan e spec pedal assist with an issue. The electric assist does not work but the torque sensor does work. The motors good and the battery is too. Please can anyone tell me what the issue is? Thank you
So the walk assist works. Therefore the motor is hooked up and working as long as the controller is telling it to go round.
Sounds like the bike isn't getting the signal that the pedals are turning. How do you know the torque sensor works?
This thread on pedelecs forum suggests the sensor can get clagged full of dirt.
