Carrera TDF gearing
DW1
Member
Hi all, new to road biking and recently bought a Carrera TDF. Happy with it except that it is hard to peddle up steeper hills ! Apparently this is due to a 52/38 front chain set and 12/26 cassette.
Am I right in thinking that just changing the rear cassette to something like an 11/32 would mean it would be much easier to go up hills without needing to replace the more expensive front chain set ? Any other issues which that would raise ? Any advice gratefully received.
Joffey
Big Dosser
Yorkshire
I have the same problem with my Carerra.
To change the rear cassette I was told I prob need to change the derailleur to a med or long cage one, also same prob if changing the front.
I've persevered and my times are picking up on the hills. Also there is no shame stopping half way up it at the top.
Give it a few more weeks before you start changing stuff.
raindog
er.....
France
As Joffey suggests - give it a bit longer and your legs will get bigger!
I've got 39x26 on my steel bike and I can get up all my local hills on it, and I'm an old fogey. ^_^
SpokeyDokey
67, & my GP says I will officially be old at 70!
Well as you are new to road riding I'd bite the bullet and get a new cassette/derailleur as yours sounds like a demoralising combo for new starters.
Try that first and then maybe a smaller small front ring if poss'.
Pontefract
I am not sure but I dont think you can go much smaller than a 38 on a double. If you go down the route of changing the rear end an Acera M.T.B. mech will do up to a 34 rear, though I think a 30 might be low enough on a 38 front ring say a hg51 11-30 the 38x30 will give you a gear" of about 33" compare with your current set up of 38x26 of about 38", my lowest on a triple with a 30th inner and 26th rear is about 30" a rear 32 would give you 31".
Cycleops
Accra, Ghana
Changing the cassette to one with a 32t or 34t lowest gear will help you. You will also need a med cage derailleur, if you shop around they will cost you about fifty quid. If you want to do it yourself you will need some tools unless your LBS does it for you.
Pontefract
The sora on my bike wouldn't do more than 28th.
Cheapest way certainly whilst getting some fitness is to put a M.T.B. mech on Acera's are fine if a little heavy, I use one, just haven't bothered changing it back to the sora, it will have a range up to 34th, I think they can be had about the £20 mark, a couple of months and when fitter it can be changed back.
DW1
Member
Thanks for all the useful info so far.
Have also talked to Halfords, it seems that one may need a medium or long cage derailleur if more than, say 28t - although there might be a "hybrid cassette" (which Halfords don't sell) which could do the job without a derailleur change.
Or, change the chain set to a compact 50/34 from the current Prowheel 52/39 and leave the rear the same (would need to take a link or two out of the chain). For about 50 quid (parts), this would apparently make quite a big difference.
Looks like there are loads of different medium and long cage derailleurs out there for loads of different prices - anyone know which ones would fit the TDF - current rear mech is Shimano RD 2300 ?
Thanks in anticipation.
Pontefract
The front mech will need to be lowered so it's nearer the chainring, the easiest option is a M.T.B. rear derailleur new cassette with upto 32 or 34 th, you will also need a new chain.
Acera MT.B. £17.50.
H.G. 50 cassette £15.39 either 11-32 or 11-30
8sp chain KMC £7.19
If your doing yourself you may need the tools to remove the chain and cassette, but once you have done this once or twice its easy, it also possible to make up your own ratios.
festival
Make do with what you have and get fitter.
Seems a bit daft to buy a budget bike and then start spending money on customizing it to suit your needs.
You could have got something like the Giant defy 5 with compact c/set and 11/28 8sp etc for not a lot more and have twice the quality.
Pontefract
Bikes been bought trying suggest solutions, besides you learn more from doing and seeing the effects that different things do, and once fitter you can change back. Thats what I did, though I already had the bike.
Norry1
Warwick
Put an 11-28 on. That will be pretty cheap if you wait/look for a deal and will make a bit of difference.
festival
I assume he bought this particular bike because he was on a tight budget ( nothing wrong with that ) so any extra expense would be counter productive. Maybe I'm wrong and anyway not everyone wants to take things apart and get their hands dirty.
As for learning, maybe knowing what else is available and doing more research will be of more benefit to a new cyclist for the next purchase.
