Carradice Bagman Sport Support Question
Heltor Chasca
Out-riding the Black Dog
One of the saddlebags I use is a Carradice Barley. Rather than having it flap about I think I need a support of sorts.
Available, are the Bagman Sport supports. (Small ‘L’ shaped rack that fits to the saddle rails)
https://www.carradice.co.uk/products/saddle-fixing-systems
Which one do you have/recommend out of the standard or the quick release? I use a Brooks C17 with loops so either are compatible. The standard is lighter and the QR offers some flexibility/security. The standard is £32 and the QR is £49. Is it worth it?
Many thanks as always
mcshroom
Bionic Subsonic
I don't have any saddle loops on my bike so I use a QR. It works well, and it is quicker to remove the bag than removing individual straps.
The downsides are that you have to fit the QR adapter on the bag with cable ties, so you can't choose to switch bikes to one without a QR. Also the clip mechanism can be a bit fiddly to get engaged. Once you've sorted it the bag is very secure, but lining up the QR and the two pins can be a little awkward.
andrew_s
Gloucester
I recommend getting the QR version.
Without the QR, it takes a significant amount of time to attach or detach the saddlebag from the bag loops, especially if the bag is fully packed. When I've been touring with people who attach using the saddle loops, they generally leave the saddlebag on the bike and walk away with the contents in a handful of tatty carrier bags.
The Bagman QR was available for several years before the plastic QR adapter and cable tie arrangement became available.
You just set the leather straps so there's about a 1 cm loop outside the saddlebag. It adds maybe 5 seconds to the time taken to fit the saddlebag on to the QR, and the bag would swing a bit more if you use the QR without the support loop or a rack, but that's about all.
I've got the QR adapter (somewhere), but I don't use it as I prefer to use the leather loops for an off-the-bike carrying handle (the mini-carabiners subsequently exchanged for 3 mm delta maillon rapides)
Vantage
Carbon fibre... LMAO!!!
I use the Carradice Classic Saddlebag Rack
It gives a carrying handle.
I had a QR before that; however it was ugly and fiddly to attach the bag.
I use the same thing. Brilliant IMO.
I also have a Bagman Sport or Expedition (can't remember which it is) and whilst both are rated to carry 4kg more than the Classic, they have much less flexibility and if you have a low saddle like muggins here, they can still hit the mudguards/tyres. The Classic has the bag quite high.
