Nigelnaturist
- Pontefract
Having just got the above off, I have found that the drive side is a reverse thread, is this correct and if so what are the options to upgrade to a modern B.B. or isn't there.
I have an old B.B. I just took off my Viking, and the drive side shell will screw into the Carleton on both sides, but the fixed side of the B.B. (which is the left) seems to have the opposite thread left thread instead of a right one, if you get my drift.The threading will most likely be English, i.e. 24 or 26 tip. I managed to fit a sealed Campag unit of my Carlton Flyer restoration a few years a go.
I dont understand why its a very typical English bike. Thanks for the link I will go look.Bottom Brackets are a minefield, take a look at this link, if your frame is R/H thread at both sides it points to Italian or French threading.
http://sheldonbrown.com/bbsize.html
Thanks I will go see, defo English thread both cups are marked 1.37x24TNigel I have edited my post have a look at the Carleton site link, may be of interest.
It seems to be, the drive side shell from the old sealed B.B. (the old one from the Viking) fits both sides on the Carlton, where as the none drive side of the sealed B.B. wont go in as the thread is wrong. I read that Raleigh used their own thread for a long time whilst most others had adopted the now standard size, its a shame I had to brae the shell off, its still usable just got a big gouge in it, I can get shorter spindles which is an option.Nigel
The drive side is usually the fixed cup and if British is a left hand thread, the adjustable cup ( left side of bike if sat on saddle is usually aright hand thread) I have re read your post above, I may have misunderstood, are you saying the Carlton has left hand threads on both sides ? if so this is very unusual.
